[SOLVED] CF PC Client - Input device error
- Contact:
Re: CF PC Client - Input device error
Ok, I managed to reproduce the issue. It's the loading of a previous configuration that is broken. If you start a new configuration from the beginning and save it (you have to configure all the axis/buttons) it should work.
individual11
Yep, works great! Thanks for the help.
thesnowedone
Ah - so guessing you don't need this now then? >< =)
- Attachments
- cfclient.zip
- (3.52 KiB) Downloaded 692 times
thesnowedone
Update: Confirming that removing the AppData/Roaming/cfclient directory and then redoing the config and including every single button solved my problem. Cheers everyone!
Now just have to wait for my nano to show up; courier is arriving today =D
Marking as solved; thanks to both of you!
SuperDave42
- Contact:
Re: [SOLVED] CF PC Client - Input device error
win7 64 I cannot get it to recognize the analog sticks on the ps3, everything but the sticks is recognized.
tried the fixes I found but not working. going to find my win XP netbook and try again.
Superluminal carbon fiber flying robots.
panguitou
Hi everybody !
Just my two cents : under linux the directory to delete (or rename) is cfclient-2013.4.1/conf
Jean-Marie
