One of quad engines still running while on battery
Re: One of quad engines still running while on battery
It sounds like a broken M4 mosfet since it worked before. Have you tried measuring the resistance like described in this post?
tomdeb
Hi Tobias,
blue-green resistance is 100ohm and blue-yellow is 10ohm, not 10k ohm as should be. So what is broken?
It is probably the mosfet that is broken then. It is not too hard to exchange if you have some soldering skills.
