Thank you for your patient instructions.
According to your instructions, I used four lines of code, and after three steps, I did get 3.8.1.
And when I use the fourth line of code in terminal, the first four feedback (4/21) are as follows:
Sending build context to Docker daemon 3.584kB
Step 1/21 : FROM ubuntu:18.04
---> c090eaba6b94
Step 2/21 : ENV DEBIAN_FRONTEND noninteractive
---> Running in 3cf342e1bf65
Removing intermediate container 3cf342e1bf65
---> f94ff0075a7a
Step 3/21 : ARG GAP_SDK_VERSION
---> Running in 200728f294e0
Removing intermediate container 200728f294e0
---> e599409b1f05
Step 4/21 : RUN echo $GAP_SDK_VERSION
---> Running in 3c4d6341cdb3
Removing intermediate container 3c4d6341cdb3
---> de08777a83c9
Is this normal?
AI-deck can't release WiFi
Re: AI-deck can't release WiFi
It seemed to not have taken in the GAP_SDK_VERSION as an argument in the container... If you have done all of those steps in the exact same terminal (without closing it in between), then there is something wrong.
What you could do now, is to replace the 'GAP_SDK_VERSION' on line 19 (under '# install gap sdk') with this:
So this will hardcore the gap sdk version to the right version.
RUN git clone https://github.com/GreenWaves-Technologies/gap_sdk.git; cd gap_sdk && git fetch --all --tags && git checkout tags/release-v3.8.1 && git submodule update --init --recursive-
Aadequate
It works!
Now I've come to the problem I met before!
Domestic network restrictions
--2021-02-25 11:50:27-- (try: 1) https://raw.githubusercontent.com/tenso ... schema.fbs
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|0.0.0.0|:443... failed: Connection refused.
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|::|:443... failed: Cannot assign requested address.
Retrying.
Because I am a novice of Linux system, I want to ask if you have a solution
Retrying.
This is a tricky problem that I'm not sure how to fix... I'll see if I can ask around here see if anybody has a clue about how to fix this.
In the mean time, did you manage to pull from GitHub on your native machine (not on docker but your linux)?
Aadequate
I can download this file successfully on Linux, just like in the attachment.
Maybe it's because I made some adjustments referring to a web page.
Like this :
cd C:\Windows\System32\drivers\etc (In windows system)
Then open hosts
Add 199.232.68.133 raw.githubusercontent.com
then in linux
sudo gedit /etc/hosts
add 199.232.28.133 raw.githubusercontent.com
I wonder if I can use a similar operation in docker
Or how can I deploy the schema file on Linux to docker?
Like this :
Then open hosts
then in linux
Aadequate
Excuse me, is there a solution to the previous problem?
Hi! sorry, this was supposed to be answered but it got lost.
We don't know how to solve this ourselves. If you are able download the repo on linux locally, I advise not to use docker and setup everything natively on your machine. You can use the steps in the docker file as inspiration how to do this properly
