After re-flashing the firmware i started getting more than one device listed in the connect menu which was odd, i connected to one and nothing happened but after connecting to the other i got some feedback before everything hung.
I then force quit the program and restarted, this time i had only one device in the menu and the debug connection and connecting to the crazyflie worked a charm. I cot disconnecetd a few times due to lost packets but after changing the channel it connects perfectly
Thanks All
[SOLVED]OSX: ui&ps3 controller work but cant connect to CF
jonathantopf
mjc506
Re: OSX: ui & ps3 controller work but cant connect to crazyf
Great
I do get weirdness after flashing firmware unless I quit and re-open cfclient. I probably should trace the bug, but I can't really be bothered
- Contact:
/Marcus
This looks good. Are you able to fly it now using the PS3 controller or are you still having problems?jonathantopf wrote: Cfclient version: 2013.4.2
System: darwin
Interface status
debug: Ok
serial: Not implemented
radio: Crazyradio version 0.5
udp: Not implemented
/Marcus
codybuell
I had a similar problem, turns out I was missing libusb as well. The OSX homebrew installation instructions on the wiki are missing `brew install libusb`.
jonathantopf
Yeah it seems like libusb was the only problem, I did put the blades on backwards first but after that it was all fine and the ps3 controller works perfectly
Next time to play!
Thanks all
ps, i wanted to mark this thread as solved but the title is too long ao i cant add any characters to it :S
Next time to play!
Thanks all
