I got Bitcraze Raspbian image 2015.3.
After booting Raspberry Pi 2, When I connect PS3 Controller and Crazyradio Pa. Nothing happens.
cfheadless.log file:
Where is the problem ?
Again, I used the bitcraze_raspberrypi.sh on existing Raspbian sdcard And still the same problem.
Thanks.
[SOLVED] The problem with Raspbian image 2015.3 & Raspberry
Crazyflie 2.0 + Crazyradio PA + Debug Adapter and LED Deck.
Re: The problem with Raspbian image 2015.3 & Raspberry Pi 2
Is your Crazyflie actually on channel 10 at 250K? If not, you'll need to edit the "link" file.
Crazyflier - my CF journal...
Raspberry Pi Ground Control.
Mac OS X Dev Environment.
THX chad, I've changed the Channel from 10 to 80, and the problem was solvedchad wrote:Is your Crazyflie actually on channel 10 at 250K? If not, you'll need to edit the "link" file.
