Radio won't show up under connect, and if I try the bootloader trick I get this
Yeah, got the driver installed. Have tried re-installing the client software as well.alex wrote:I'm running the Crazyradio successfully under Win7 Home Premium x64. Did you install the USB driver from the wiki?
Did you manage to solve this? If not, could you try inserting the dongle into a different USB port?Vertikar wrote: Yeah, got the driver installed. Have tried re-installing the client software as well.
Just tried another couple of USB ports, no difference.marcus wrote:Did you manage to solve this? If not, could you try inserting the dongle into a different USB port?Vertikar wrote: Yeah, got the driver installed. Have tried re-installing the client software as well.
/Marcus
