[SOLVED]PS3 Controller Windows XP SP3
mfunk1000
[SOLVED] Re: PS3 Controller Windows XP SP3
Post by mfunk1000 »
Let me get this flow right and try it.
Inside the Configure Input screen
- Hit detect for say thrust
- hit PS button on controller
- push right stick all the way to top
I have tried just hitting detect and moving all joysticks and hitting buttons with no luck. I even tried in the standard windows device area and did not get results their either.
Thanks again!
marcus
Post by marcus »
Yeah, that sounds like the correct way.
If you in widows go to Control Panel->Game Controllers->Properties for the PS3 controller do you manage to get some output then?
mfunk1000
Post by mfunk1000 »
I get no output in windows Game Controller section.
I will try this later this afternoon.
mfunk1000
Post by mfunk1000 »
nothing. Could it be a driver thing?
mfunk1000
Solved - PS3 Controller Windows XP SP3
Post by mfunk1000 »
Got it working!
Used Motionjoy but the real issue I found is you have to make sure that the C:\WINDOWS\system32 folder needs to be writable. By default its read only which is why you get errors in motionjoy and the drivers were not updating.
marcus
Post by marcus »
Great that it's working :D
