How to Compiling CF's FW on win7 !
Hi guys
I use Windows 7, I have already downloaded and installed the "gnu TOOL ARM EMB... (win32.exe)", but I don't know how to use and compile the CF existing source code file.Tks!
Here is my in CMD. Exe using the Make command to complete compilation of screenshot.
- Attachments
- cf WIN7
- 无标题.png (9.56 KiB) Viewed 13814 times
Re: How to Compiling CF's FW on win7 !
good news! i try to compiling CF BOOTLOAD FILES ,,,,,,it's okay !
so .why i used make command to compiling CF Firmware ...display error informations.
JoshLillie
- Contact:
Mine is not compiling.
I haven't messed with it too much, probably something missing.
C:\CF>make
AS startup_stm32f10x_md.o
process_begin: CreateProcess(NULL, arm-none-eabi-as -mcpu=cortex-m3 -mthumb -Ilib/FreeRTOS/include -Ilib/FreeRTOS/portable/GCC/ARM_CM3 -I. -Ilib//STM32F10x_StdPeriph_Driver/inc -Ilib//CMSIS/Core/CM3 -Iconfig -Ihal/interface -Imodules/interface -Iutils/interface -Idrivers/interface lib//CMSIS/Core/CM3/startup/gcc/startup_stm32f10x_md.s -o bin/startup_stm32f10x_md.o, ...) failed.
make (e=2): The system cannot find the file specified.
make: *** [startup_stm32f10x_md.o] Error 2
C:\CF>-
smokedasphalt
Hi, JoshLillie. Have you installed the GCC ARM Embedded tools? If not, then download the installer for windows from here https://launchpad.net/gcc-arm-embedded/+download . Once that is done, go to the directory where you installed the tools, and just have a look inside the bin folder. You should see a lot of. exe files beginning with arm-none-eabi-. Now, copy the full path of the bin directory and append it to the system PATH variable. This is easy to do. Check Google (Sorry, I'm on my phone or I'd have told you how to do it. ) Restart the command prompt and try compiling again.
Hi smilies...Can you tell me my Crazyfile firmware compile: why can't I success? (I've been install GCC ARM Embeded tools on win7) but I'm crzayfile bootloader FW to compile a success?
JoshLillie
- Contact:
@smokedasphalt - Thanks for the tip! I thought I had that installed, but I recently uninstalled a bunch of stuff. It got a lot further, but now I'm getting the version.c error others have mentioned.
C:\CF\bitcraze-crazyflie-firmware-e6f9fbdc42b3>make
CC list.o
CC tasks.o
CC queue.o
CC timers.o
CC heap_4.o
CC port.o
CC misc.o
CC stm32f10x_adc.o
CC stm32f10x_dbgmcu.o
CC stm32f10x_dma.o
CC stm32f10x_exti.o
CC stm32f10x_flash.o
CC stm32f10x_gpio.o
CC stm32f10x_i2c.o
CC stm32f10x_iwdg.o
CC stm32f10x_rcc.o
CC stm32f10x_spi.o
CC stm32f10x_tim.o
CC stm32f10x_usart.o
CC main.o
CC led.o
CC uart.o
CC adc.o
CC nrf24l01.o
CC exti.o
CC nvic.o
CC motors.o
CC mpu6050.o
CC i2cdev.o
CC i2croutines.o
CC hmc5883l.o
CC ms5611.o
CC crtp.o
CC ledseq.o
CC freeRTOSdebug.o
CC imu.o
CC pm.o
CC radiolink.o
CC eskylink.o
CC system.o
CC comm.o
CC console.o
CC pid.o
CC crtpservice.o
CC param.o
CC commander.o
CC controller.o
CC sensfusion6.o
CC stabilizer.o
CC log.o
CC worker.o
CC filter.o
CC cpuid.o
CC cfassert.o
CC configblock.o
CC eprintf.o
CC crc.o
CC fp16.o
CC debug.o
VTMPL version.c
File "scripts/versionTemplate.py", line 20, in <module>
identify = subprocess.check_output(["hg", "identify", "-nitb"])
File "C:\Python27\lib\subprocess.py", line 537, in check_output
process = Popen(stdout=PIPE, *popenargs, **kwargs)
File "C:\Python27\lib\subprocess.py", line 679, in __init__
errread, errwrite)
File "C:\Python27\lib\subprocess.py", line 896, in _execute_child
startupinfo)
WindowsError: [Error 2] The system cannot find the file specified
make: *** [version.c] Error 1
C:\CF\bitcraze-crazyflie-firmware-e6f9fbdc42b3>-
smokedasphalt
@gl516 - Hi, I'm sorry but I don't comprehend you. It looks like you are compiling the bootloader. Why would you want to do that? If you want to compile the firmware, please make sure you have downloaded the correct files and refer to the wiki so that you don't go wrong. I think you have all the tools installed and working.
@JoshLillie - Have you installed Mercurial for windows? Is it in your PATH? (Type hg in the command prompt and you should see some output instead of an error.) Once that is done, clone whichever repository you want by running hg clone URL after replacing URL with the link to the repository. (for example, if you want to clone the firmware by Bitcraze, the command looks like hg clone https://bitbucket.org/bitcraze/crazyflie-firmware)
Hi smokedasphalt
......My purpose is how to compile the CF 'S firmware, not in order to compile the CF' S BOOTLOADER firmware (this only to test the function). I have been in the GCC installed in the Windows 7 ARM Emb and python 2.7... Is not installed any other things (such as openocd...) .
smokedasphalt
gl516 wrote:My purpose is how to compile the CF 'S firmware
Have you installed Mercurial? Make sure it is in your PATH. Then clone the firmware repository using hg clone URL. (Refer to my reply to JoshLillie in my previous comment.) Once you have the repository, cd into it and then run make CLOAD=1gl516 wrote:GCC installed in the Windows 7 ARM Emb and python 2.7
The entire process looks like this
C:\Users\Test\Desktop>hg clone https://bitbucket.org/bitcraze/crazyflie-firmware
C:\Users\Test\Desktop>cd crazyflie-firmware
C:\Users\Test\Desktop\crazyflie-firmware>make CLOAD=1
Build 38:e6f9fbdc42b3 (tip) CLEAN
CrazyLoader build!
text data bss dec hex filename
48060 400 19344 67804 108dc cflie.elf
rm version.cRe: How to Compiling CF's FW on win7 !
What's this " Mercurial"?
I don't have to install this in my PC. Can you provide a download links for me , I will be installed on Windows 7....
