Crazyflie Bootloader Flasing: No DFU cable USB device available
cboustead
Post by cboustead » Wed Feb 06, 2019 2:06 pm
I'm setting up PX4 on my Crazyflie 2.0. I'm having an issue trying to flash the bootloader using USB. I get the message "dfu-util: No DFU capable USB device available". The cable I am using is a Micro USB -> USB and then I'm using a USB -> USB-C for my Mac.
When I execute the command "dfu-util -l --list", no devices are found.
Can anyone confirm whether this issue is because I am using an adapter rather than a cable straight through?
Re: Crazyflie Bootloader Flasing: No DFU cable USB device available
Post by arnaud » Wed Feb 06, 2019 2:37 pm
To boot the stm32 in DFU mode you should press the power button about 5 seconds until the LED is blinking fast. You might need to click the button once more after that. Are you doing this procedure?
cboustead
Post by cboustead » Wed Feb 06, 2019 3:32 pm
Yes, I have been putting it into the Bootloader mode. The LED is blinking fast.
Post by arnaud » Thu Feb 07, 2019 9:36 am
Are you sure your cable is working for data? (for example usb cables shipped with USB batteries usually do not have the data lines cabled...).
For reference, I tried on our dev mac and without battery, I press the button, connect the USB cable and release the button when the LED blinks fast, I get the bootloader to appear in the system report:
cboustead
Post by cboustead » Thu Feb 07, 2019 10:01 pm
I tried with a new data cable today. I do not see any bootloader appear in my system report. Any ideas?
cboustead
Post by cboustead » Fri Feb 08, 2019 12:26 am
Hold on, it's working! The "without battery" was the most important part for your comment. Thanks
