Crazyradio PA is busy with a previous request on VM
ricardo.halfeld
Post by ricardo.halfeld » Thu Oct 11, 2018 7:44 pm
Good evening,
I'm struggling to get the VM working as described in the tutorials. I have managed to install the Windows drivers and run the Crazyflie client successfully (on Windows). I have also had success with the example Python scripts. All that to say I believe I have all things set correctly on Windows.
However, when I open the VM on Virtualbox, things no longer work as suggested by the tutorials. With the Crazyradio PA connected, I click the USB icon on the bottom right of the VM screen and try to select the Crazyradio PA to no avail.
I get the following message:
When I run
lsusb
the Crazyradio doesn't show. It is only when I select the Generic USB2.0-CRW in the USB list on the bottom right of the VM screen that I find something, though it doesn't really resolve the issue.
I haven't found another case reflecting the same conditions of this issue, but I'm also not experienced with virtual machines or even Linux for that matter, so I'm sorry if you already solved this one. I appreciate your input.
Thanks!
Re: Crazyradio PA is busy with a previous request on VM
Post by tobias » Wed Oct 17, 2018 9:15 am
To me it sounds like something in windows is still using the Crazyradio PA. Could that be it?
ricardo.halfeld
[SOLVED] Crazyradio PA is busy with a previous request on VM
Post by ricardo.halfeld » Wed Oct 24, 2018 11:58 am
Good call.
Indeed restarting the computer and opening the VM before anything else allowed the VM to connect to the Crazyradio PA. Thanks for the suggestion.
Any further suggestions on how to find what is using the dongle if it ever happens again?
