AntenaDelay
skeletonSir
AntenaDelay
DWM1000 with PA is being used,How much antenna delay should be set,
dwTime_t delay = {.full = 0};
dwSetAntenaDelay(dwm, delay);
writeValueToBytes(dev->antennaDelay.raw, 16384, LEN_STAMP);
skeletonSir
Re: AntenaDelay
Use DWM1000 with PA, the distance is not accurate, need to revise where
Re: AntenaDelay
The antenna delay is applied in software in our TWR algorithms, we have stopped using the antenna delay register in the DW1000.
I am not sure what you mean by "DWM1000 with PA", but if you are not using the stock DWM1000 you most likely need to adjust the antenna delay used in the TWR algorithm.
skeletonSir
Re: AntenaDelay
TWR mode ranging is correct, but TDOA mode ranging is wrong, because I used DWM1000 power amplifier, how should the antenna delay and time be modified?
skeletonSir
Re: AntenaDelay
To be exact, DWM1000 with power amplifier is tested with Anchor mode and tag mode in LPS. One Anchor and one tag, the test results are more consistent with the real results. Although there is a little deviation, it is adjustable, but the data analyzed by the aircraft end is wrong with 8 TDOA2 or TDOA3 Anchor points.What needs to be changed in the TDOA algorithm?
Re: AntenaDelay
I understood the Power Amplifier part but I am still not sure of what hardware you are using, so to be clear: if you are using a DWM1000 module that is different than this one: https://www.decawave.com/products/dwm1000-module the antenna delay in Two Way Ranging mode needs to be re-calibrated.
As long as you are using similar UWB radio in all your system (ie. if all the antenna delay are very similar), you should not need any antenna delay calibration for TDoA: when calculating the time difference of arrival the antenna delay gets canceled.
skeletonSir
Re: AntenaDelay
The antenna is the same, namely the antenna and DWM1000 chip added a PA, as shown in the figure.In that case, the antenna delay need not be changed, where to change with TDOA mode?Timestamp?
- Attachments
- 123.png (76.86 KiB) Viewed 10934 times
- 12.png (48.88 KiB) Viewed 10934 times
skeletonSir
Re: AntenaDelay
I'm going to use PA for the anchor point plus PA for the plane.Or make an airplane with PA as anchor point + PA, the data of TDOA is not correct
Re: AntenaDelay
When using TWR you must recalibrate the antenna delay, antenna delay is the delay of everything that is after the DW1000 radio I/O this include part of the silicon, traces on the PCB, antenna as well as any PA that is before the antenna.
Can you precise how does TDoA not work? We have never used these module so I have no idea about how they behave and what they could cause to the measurements.
Re: AntenaDelay
Hi
I just tested a TWR ranging accuracy between one node and one crazyflie.
The ranging data was from LoPoTab0 - ranging.distance0.
The data showed ranging error of over 300mm.
Is this also a problem of antenna delay?
If it is, is there some kind of criterion which value should I fit in? or should i just find the value experimentally?
Thanks!
Thanks!
