hi, arnaud:
if disable imu, only uwb, can we get the right and stable position ?
remove imu, only uwb, tdoa position
- Expert
Re: remove imu, only uwb, tdoa position
Maybe, it depends of what is your expectation of 'stable'. In theory the absolute position quality should be the same, but the dynamic performance should be worse since the IMU is used for short-term movement.
If you test I am interested to hear about the result
- Expert
hi,
ok, I will try, and can 4 anchors get the tag's 2D position, no need z axis ?
This can be done by feeding a fixed (roughly accurate) Z position input to the kalman filter. For an example of how to feed Z position you can look at the z-ranger deck driver.
- Expert
with hyperbolic method, I have geted the tag's position, thanks.
and I also try your method
