remove imu, only uwb, tdoa position
justinleeyang
Post by justinleeyang » Wed Mar 21, 2018 10:42 am
hi, arnaud:
if disable imu, only uwb, can we get the right and stable position ?
Re: remove imu, only uwb, tdoa position
Post by arnaud » Mon Mar 26, 2018 10:49 am
Maybe, it depends of what is your expectation of 'stable'. In theory the absolute position quality should be the same, but the dynamic performance should be worse since the IMU is used for short-term movement.
If you test I am interested to hear about the result ;-).
justinleeyang
Post by justinleeyang » Wed Apr 04, 2018 3:11 am
hi,
ok, I will try, and can 4 anchors get the tag's 2D position, no need z axis ?
Post by arnaud » Wed Apr 04, 2018 8:59 am
This can be done by feeding a fixed (roughly accurate) Z position input to the kalman filter. For an example of how to feed Z position you can look at the z-ranger deck driver.
justinleeyang
Post by justinleeyang » Wed Apr 04, 2018 12:04 pm
with hyperbolic method, I have geted the tag's position, thanks.
and I also try your method
