Capture flight path
Capture flight path
Hi - is there a way to record the variations in thrust/pitch/yaw/roll during a single flight and then have a button pushed to replay the exact same variations? I know environment (air drafts, etc.) would change the exact flight path each time, but just looking for replay of input.
Re: Capture flight path
There is no such things implemented in the client right now.
I do not think it would be very hard to implement a recording functionality to the python client that saves the sequence of commander values sent to the copter and play it back with a custom python script. It will not be perfect but I guess in theory, using the same Crazyflie in the same condition, you should get a quite similar flight when playing back. However I suspect the results will vary a lot depending of the copter and the battery voltage.
