Altitude hold mode
Posted: Wed Aug 13, 2014 8:19 am
I use the VM 0.4 and write programs in Python.
I can't get the altitude_mode to work with coding. I am able to search and connect to the Crazyflie and send setpoints and making it takeoff, but I am unable to go into altitdehold_mode.
This is my code, why doesnt it work?
The whole while loop is my interpretation of what is discussed in this thread: http://forum.bitcraze.se/viewtopic.php?f=6&t=883
When using a PS3-controller I can use the hovermode, but you have to hold the button, therefore it would make sense to set the altholdmode to "True" every 10ms a sort of "digital hold". I guess the error lies in the loop but Im really lost and could use some help.
Thank you
print "sending initial thrust of 50 000"
cf.commander.send_setpoint(0,0,0,50000);
time.sleep(0.5);
print "putting in althold"
cf.param.set_value("flightmode.althold","True")
print "Stay in althold for 7s"
it=0
while it<700:
cf.commander.send_setpoint(0,0,0,32767)
time.sleep(0.01)
it+=1
print "Close connection"
cf.commander.send_setpoint(0,0,0,0)
cf.close_link();
Thank you
