can't control the crazyFlie
loro
Post by loro »
Hi at all. I start to playing around with my CrazyFlie but I can't controll it.
This is what I do:
I put the copter down on the floor and turn it on. Wait until Selftest is passed, start the PC-Client Software and connect to the Copter. The Actual Values are Pitch: about 0.60 Roll: about -0.50 Yaw: depend on copter orientation and ASL about 93.24, when the Copter lying on the floor.
If I try to start flying the coter Pulls to the right. It seams to me that I can't change the direction from my Copter because there is no reaktion on a Pitch- or Roll-command.
I use the latest Firmware Crazyflie_2014.01.0 on my 10DOF (OS is Win7 Prof.) cfclient 2014.01.0.
What can I do to get a better control about my copter or to change the direction.
Best regards Chris
Re: can't control the crazyFlie
Hi Chris,
Are you sure that you are using the correct input-device mapping? If you look in the UI at the target values when moving the analog sticks on the controller, you should see that you can manipulate all the axis. If not then there is an issue with the mapping. There's some instructions on the wiki.
The mapping can be seen in the lower left of the client together with the selected input-device. The mapping and input-device can be changed from the Input device menu.
