[SOLVED]debug://0/0 - Debugdriver for UI testing
Posted: Wed Jan 15, 2014 5:06 am
by baicker
I have seen the "debug://0/0 - Debugdriver for UI testing" only one time in the client, (i can't remember when and how)
but now, when i pluging the crazyradio and pressing the scan button, i can see nothing,
is it something wrong with the crazyradio or other problems ?
(the crazyradio can be recognized by the system in VM )
Re: debug://0/0 - Debugdriver for UI testing
Posted: Thu Jan 16, 2014 10:06 am
by arnaud
The debug driver has been removed by default to limit confusion. It is only intended to test the client software, if you want it back you can re-enable it by manually editing the config.json file.
Do you see that the radio is found in help/about/debug?
Posted: Thu Jan 16, 2014 10:19 am
by baicker
arnaud wrote:The debug driver has been removed by default to limit confusion. It is only intended to test the client software, if you want it back you can re-enable it by manually editing the config.json file.
Is the serial:None right?
Cfclient
Cfclient version: 2013.11-beta1
System: linux2
Interface status
serial: None
radio: Crazyradio version 0.52
udp: None
Crazyflie
Connected: None
Firmware: None
Sensors found
Sensors tests
Posted: Thu Jan 16, 2014 12:17 pm
by tobias
Is the Crazyflie running as it should? The Crazyradio seam to be working. When you press connect button does the red LED on the Crazyradio blink?
Posted: Thu Jan 16, 2014 12:28 pm
by baicker
tobias wrote:Is the Crazyflie running as it should? The Crazyradio seam to be working. When you press connect button does the red LED on the Crazyradio blink?
i solved all the problems, i understand finally, i have flashed the cflie.bin without the crazyflie bootloader by jtag
thank you tobias, thank you arnaud.
