Problems with AI deck and bootloader
Posted: Sun Apr 24, 2022 11:00 am
I'm working on the AI deck for my master thesis at university of L'Aquila and i have some problems.
I've seen that the topic is hot and new so, due to the lack of JTAG cable component, i'm trying to do all the stuffs via WIFI and using the crazyradio.
I've updated the crazyflie firmware and the nrf one too without any problems.
I setupped via tb make menuconfig my access point and my pc sees the AI deck AP and can connect (the NINA led flashes fast).
The real problem is that i shurely compromised something regarding the GAP8. Infacts the LED2 does not blink.
I tried to upload the bootloader using what Marcus said in other posts, and as first try it worked untill 60% of installation, then the crazyflie restarted and now if i retry, i'm stuck with "socket connected" and nothing happens.
My experience with embedded systems is low and is an academy level. So i struggle finding what is really happened in a such low level.
What can i do? Do i really need the JTAG cable?
Thanks all for the help!
P.S. I tried to upload the wifi stream example but it stucks at 2%.
P.P.S. Randomly, the LED2 returns to blink, after change an empty battery with a charged one. I'm so confused.
More updates: with the help of the console tab of the cfclient, this string comes: "ESP32: W (121464) ROUTER: Cannot route from GAP8 [0x00] to [0x00]" when the terminal is stuck with "socket connected".
