Lighthouse V2 calibration data
Posted: Tue Feb 22, 2022 8:29 pm
I don't understand how the script is used to find the calibration data, the port where my valve is connected is ttyACM0, and I'm using the get_lh2_calib_data.py script, but I don't understand how I put the port information to use it. These are the steps to use it:
# Usage:
# 1. Connect a USB cable to a lighthouse 2 base station
# 2. Run the script, use the serial port (usually something like
# /dev/tty.usb123456) together with the --dev switch.
# >>> get_lh2_clib_data.py --dev /dev/tty.usb123456
# 3. Copy/paste the output into the appropriate app or other file.
but I don't understand how to use it and where is the get_lh2_clib_data.py script
Thanks for help
# Usage:
Thanks for help
