Off board low level control
Posted: Tue Feb 22, 2022 10:35 am
Hello
I am currently in the process of developing some non linear controller for autonomous flight with drones, and would like to test them on the Crazyflie 2.1.
I have little to no experience in C and does therefor not expect to be able to implement the controller onboard the Crazyflie itself. The approach I would like to use it to implement the controller in Simulink and send the motor commands to the Crazyflie via the Crazyflie radio dongel. Position and orientation data will be provided from an Opti track system.
I have seen in other block post that it may be possible to use python commands to set the desired voltage/Pwm value for each motor individually but have been unable to find any documentation for this.
Is anyone aware of any documentation for this, or have any experience with doing direct motor control on the Crazyflie?
