I am trying to flash my Crazyflie 2.1 but it will always "break" i.e only M2 will have staric blue light
Posted: Tue Sep 28, 2021 1:04 pm
When i say flash I mean: https://www.bitcraze.io/documentation/r ... ing/build/
When i run "make cload" (after make) i get:
Each time i do this the crazyflie just makes a single static light at M2
I have followed this guide: https://www.bitcraze.io/documentation/r ... ing/build/
I have downloaded all the dependencies (arm and python ) and I can make the files. I also have crazyflies-clients python downloaded and installed in the correct place Crazyflie/crazyflies-clients python . Did i download the wrong firm ware? I got it from here https://github.com/bitcraze/crazyflie-firmware
If i do the ubunto command "ls" on my crazyfile folder this is what i have:
The website from the beginning says i have to "The current working directory is the root of the crazyflie-firmware project" is this not where I ran my "ls" command too? So i did it in the correct place.
python3 -m cfloader flash tag.bin stm32-fw
Restart the Crazyflie you want to bootload in the next
10 seconds ...
Flashing 1 of 1 to stm32 (fw): 234267 bytes (229 pages) ..........10..........10..........10..........10..........10..........10..........10..........10..........10..........10..........10..........10..........10..........10..........10..........10..........10..........10..........10..........10..........10..........10.........9
app_api docs module.json tag.bin test
bin examples Rakefile tag.dfu tools
CONTRIBUTING.md generated README.md tag.elf vendor
crazyflie-clients-python LICENSE.txt RELEASE_CHECKLIST.md tag.hex version.c
current_platform.mk Makefile src tag.map
