Failed in running PMSIS helloworld example on AI-deck's board
Posted: Mon Aug 02, 2021 9:52 am
Hello!
I'm using the GAP_SDK in docker within the crazyflie's VM. I'm trying to execute the PMSIS helloworld example on the AI deck processor but the execution ends up failing due to the following error:
I can't really tell what is wrong. I made sure that the olimex-arm-usb-tiny-h interface is connected to the VM by using the command lsusb. I also made sure to use $source configs/ai_deck.sh and $export GAPY_OPENOCD_CABLE=interface/ftdi/olimex-arm-usb-tiny-h.cfg in the main sdk directory. What could be the issue?
Launching execution with command:
gap8-openocd -c 'gdb_port disabled; telnet_port disabled; tcl_port disabled' -f interface/ftdi/olimex-arm-usb-tiny-h.cfg -f target/gap8revb.tcl -f tcl/jtag_boot_entry.tcl -c 'gap8_jtag_load_binary_and_start "/gap_sdk/examples/pmsis/helloworld/BUILD/GAP8_V2/GCC_RISCV/test" elf 0x1c000080'
Open On-Chip Debugger 0.10.0+dev-gb84d97ec4 (2021-07-15-09:59)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.org/doc/doxygen/bugs.html
DEPRECATED! use 'adapter speed' not 'adapter_khz'
DEPRECATED! use 'adapter driver' not 'interface'
Warn : Interface already configured, ignoring
TARGET create
Info : core 0 selected
0
Info : gap8_adv_debug_itf tap selected
Info : adv_dbg_unit debug unit selected
Info : Option 7 is passed to adv_dbg_unit debug unit
GAP8 INIT TARGET
Error: libusb_open() failed with LIBUSB_ERROR_NO_DEVICE
Error: no device found
Error: unable to open ftdi device with vid 15ba, pid 002a, description 'Olimex OpenOCD JTAG ARM-USB-TINY-H', serial '*' at bus location '*'
File "/gap_sdk/tools/gapy/gapy", line 162, in <module>
main()
File "/gap_sdk/tools/gapy/gapy", line 152, in main
operationFunc(args, config)
File "/gap_sdk/tools/gapy/run.py", line 146, in operationFunc
raise RuntimeError('Runner has failed with value: %d' % status)
RuntimeError: Runner has failed with value: -1
/gap_sdk/tools/rules/pulp_rules.mk:244: recipe for target 'run' failed
make: *** [run] Error 1
root@4f657d0612c8:/gap_sdk/examples/pmsis/helloworld#
