Errors in multiranger_pointcloud.py
Posted: Fri Jul 09, 2021 7:35 pm
When attempting to run the example script multiranger_pointcloud.py, I encountered the following error message.
"'CanvasBackend' object has no attribute 'setParent'"
Any sense of what might be causing this? Might this be a shortcoming of my setup (or a library I failed to install)? Or is this a problem with the code listed on the github?
Thanks!
Thanks!
