Page 2 of 2
Re: Hardware all properly set up but lighthouse deck not being initialized
Posted: Fri Jun 18, 2021 1:23 pm
by Jadenbh12
Okay so now I can flash the firmware, but for some reason the deck isn’t updating. The blue progress bar finishes and the crazyflie restarts twice, but when I reset it the deck still has the blue and red lights on. Also in the console it says that there are 0 decks detected despite the fact that I have one connected. So it’s just not detecting or updating at all.
Posted: Fri Jun 18, 2021 1:39 pm
by kimberly
Alright, so a red led and blue led is good, but the not connecting properly is bad. It seem to be a connection problem now
Perhaps you can try:
- remove and then reattach the deck
- disconnecting and reconnecting the battery of the crazyflie
Posted: Fri Jun 18, 2021 5:43 pm
by Jadenbh12
Okay so I have the firmware flashed and the blue and yellow leds are on for the deck. Can I ask how to set up the base stations? I have two of the v1.0 and I haven’t been able to find a reliable guide
Posted: Mon Jun 21, 2021 9:59 am
by kimberly
For the v1's, you just need to set them in the right mode, which can be found
in the instructions if you click the 'v1 base station' tab.
Technically, for physicall setting them up it is exactly the same. You can either use a tripod like in the video, or use a wall mount. HTC vive has some [more setting up instructions](
https://www.vive.com/hk/support/vive/ca ... tions.html) which shows how you can set it up physically. However, the whole setting it up in software is not necessary as that is being done in the cfclient (as according to the bitcraze tutorial instructions).
