RoadRunner inside the docker doesn't work 'The device has no langid'
Posted: Wed May 12, 2021 2:34 pm
If I try to call cflib.crtp.scan_interfaces() outside the docker it works fine, but inside the docker it raises the following problem 'The device has no langid'. I start the docker with the permission to read the Usb. Do you have any idea where is the problems?
