Do not fly
Posted: Fri May 07, 2021 5:55 pm
I bought two SteamVR V2 station and the lighthouse deck. I followed the tutorial https://www.youtube.com/watch?v=DCEHht72B08, but when I tried to use the take off button nothing happened. I manually moved the drone and the system appeared to be working.
I also tried to use the autonomous_sequence_high_level.py script and it just threw itself in a random direction with a height of less than 10 cm.
PS: I can fly with xbox control using or position hold mode within the steamVR area, but I don't know if he is using the lighthouse data.
