CrazyradioPA isn’t recognised on Mac or PC.
Posted: Fri Mar 26, 2021 12:54 pm
by Pandemonium
I wonder if anyone can help ?
I had the virtual machine working fine on my Mac Desktop.
I decided to install the VM on my Windows 10 laptop.
When I did this the CrazyradioPA was not recognised on the PC, although I installed the driver from Zadig - I tried all 4 versions - CrazyradioPA is recognised by the PC (see photo.)
I tried my Mac again, things booted-up fine - for 10 seconds - then I got this message (Error message on Mac - photo)
I now can’t get the CrazyradioPA to work on either computer.. any ideas why this is happening ?
Many thanks
Re: CrazyradioPA isn’t recognised on Mac or PC.
Posted: Mon Mar 29, 2021 6:48 am
by kimberly
Which virtual machine program are you using? And if you are using virtual box, have you installed the extension pack that supports USB 2.0 and 3.0?
Posted: Mon Mar 29, 2021 9:37 pm
by Pandemonium
Hello Kimberly
On the Mac I’m using virtual box 6.1 with the extension pack installed. Both the CrazyradioPA and Sony PlayStation controls are showing up on the USB settings.
On the PC running windows I’m using the basic VM.
Posted: Wed Mar 31, 2021 8:09 am
by arnaud
Your first screenshot seems to be taken on a mac, not on Windows. The second one hints of a problem with the gamepad and not with the radio, it comes from the gamepad being disconnected.
Does the radio appears in the USB menu of VirtualBox in both windows and Mac? The USB device needs to be manually passed to the VM each time you want to use it.
Posted: Wed Mar 31, 2021 5:25 pm
by Pandemonium
There’s no problem with the game pad.
The issue is with the CrazyradioPA !
It will not connect to the Mac - it will not connect to the PC either.
Let’s start with the Mac, as it was working fine until I tried the CrazyradioPA in the PC.
Then I got the message in the picture on the Mac.
Thanks David
Posted: Wed Mar 31, 2021 5:28 pm
by Pandemonium
The CrazyrarioPA and Gamepad are showing in the USB menu in the VM on both computers
Posted: Thu Apr 01, 2021 9:16 am
by arnaud
The error message you took a screenshot of is emitted by linuxjsreader.py which is the gamepad driver used in the client, it does comes from the gamepad. Though, the error is about the device being disconnected so since both the gamepad and the radio are connected over USB, there might be a link.
One way to debug the situation is to find-out if the radio is seen on the Linux side in the VM. After you pass the radio to the VM, it should appear both in "dmesg" and in "lsusb", by typing both commands in the console just after passing the radio to the VM you should get something like that:
$ dmesg
<lots of text ....>
[ 9227.201276] usb 1-2: new full-speed USB device number 12 using xhci_hcd
[ 9227.363546] usb 1-2: New USB device found, idVendor=1915, idProduct=7777, bcdDevice= 0.53
[ 9227.363560] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=29
[ 9227.363567] usb 1-2: Product: Crazyradio PA USB Dongle
[ 9227.363571] usb 1-2: Manufacturer: Bitcraze
[ 9227.363575] usb 1-2: SerialNumber: ************
$ lsusb
<lots of entries ...>
Bus 001 Device 012: ID 1915:7777 Nordic Semiconductor ASA Bitcraze Crazyradio (PA) dongle
If that happens, the next things to look at is the log when launching the client. You can launch the client from the console with the command "python3 -m cfclient.gui", it the radio is well recognize, towards the end there should be the line "INFO:cflib.crtp.radiodriver:v0.53 dongle with serial N/A found
", otherwise there should be an error indicating that the radio could not be opened.
If the radio gets disconnected, both lsusb and dmesg are good commands to get more information about what happened.
Posted: Thu Apr 01, 2021 9:42 am
by Pandemonium
Many thanks Kimberly - I’ll give that a go and let you know how things go. I appreciate your help ! David
