Assert failed after watchdog timeout.
Posted: Mon Mar 01, 2021 1:41 am
I have CF2.1 with lighthouse deck and flow deck. I added one custom deck (written in software) which is supposed to copy the EKF filter operation for my research. The code is compiling fine in computer with the makefile; however, I have following as the output when it is flashed in the cf2.1:
I went to cfJacobian line 35 and it is the following:
I have attached the whole file in the attachment. Please let me know what I am missing and how to correct this. Thanks.
SYS: Assert failed .//src/deck/drivers/src/cfJacobian.c:35
SYS: Build 29:5d4350e645a2 (2020.04 +29) MODIFIED
ash!
ngine found
DECK_INFO: compile-time forced driver ekfOptiEngine added
DECK_CORE: 2 deck(s) found
DECK_CORE: Calling INIT on driver ekfOptiEngine for deck 1
Hello Crazyflie 2.1 deck world!
EEPROM: I2C connection [OK].
ekfOptiEngine test passed!
DECK_CORE: Deck 1 test [OK].
SYS: The system resumed after watchdog timeout [WARNING]
SYS: Assert failed at .//src/deck/drivers/src/cfJacobian.c:35
.//src/deck/drivers/src/cfJacobian.c:35Code: Select all
static inline float arm_sqrt(float32_t in)
{ float pOut = 0; arm_status result = arm_sqrt_f32(in, &pOut); ASSERT(ARM_MATH_SUCCESS == result); return pOut; }
