Lighthouse positioning deck SPI usage [SOLVED]
Posted: Fri Jan 29, 2021 3:55 pm
Hi all,
this seems like an obsolete question but it is very important for me to clarify it.
The SPI- and the UART2-Pins on the lighthouse deck are only used when the bootloader needs to be flashed. So the SPI and UART2-Pins can be used for anything else when the 0ohm-resistors R11-R15 are not soldered on the deck. Do I understand this correctly?
On the shop-website the image showing the back of the lighthouse positioning deck seems to show the deck with the resistors soldered. Will the board be sent with the resistors soldered or not soldered?
Best regards,
devjalx
Best regards,
devjalx
