I am running a collision avoidance algorithm on the drones that I have and I would like to plot the flight trajectory of each drone.
To this purpose I am trying to log the position of each drone during the flight.
I am using the following script for flight control:
    # imports and other data above...
 lg_vars = {
                  'drone.id' : 'int32_t',
                   'drone.posX': 'float',
                   'drone.posY': 'float',
                   'drone.posZ': 'float',
if __name__ == '__main__':
    cflib.crtp.init_drivers(enable_debug_driver=False) # initialize drivers
    factory = CachedCfFactory(rw_cache='./cache')
    with Swarm(uris, factory=factory) as swarm:
    		lgr = l_and_p.LogAndParam('Position', lg_vars, 100, swarm)
      	        swarm.parallel(lgr.simple_log_async)
    # more code below...
# more code above...
class LogAndParam:
    def __init__(self, name_conf, vars, prd, swarm = None):
        self.num_of_qds = 5
        self.lg_stab = LogConfig(name=name_conf, period_in_ms=prd)
        self.recordingLstPos = {str(k) : [] for k in range(0, self.num_of_qds)}
        for key in vars:
             self.lg_stab.add_variable(key, vars[key])
    def log_stab_callback(self, timestamp, data ,logconf):
        kys = np.array(list(data.keys()))
        self.recordingLstPos[str(data['drone.id'])].append( [ float(data[ kys[1] ]), float(data[ kys[2] ]), float(data[ kys[3] ]) ] )
    def simple_log_async(self, scf):
        cf = scf.cf
        cf.log.add_config(self.lg_stab)
        self.lg_stab.data_received_cb.add_callback(self.log_stab_callback)
        self.lg_stab.start()
        time.sleep(0.1)
