Getting started with Bolt and ESC Calibration [solved]
Posted: Tue Nov 24, 2020 1:56 pm
Hi.
I would like to calibrate ESCs with the bolt flight controller.
I have understood that I should somehow initiate a calibration command from the flight controller to the ESC. Then ESC will register maximum thrust from the controller (= maximum PWM value from bolt). Is there any way to do this kind of calibration with bolt?
My setup is similar to this post: viewtopic.php?f=3&t=4474 but little bit smaller scale. I am using T motor Air 2216 880KW motor with Air 20A esc. https://store-en.tmotor.com/goods.php?id=727
In my setup ESC power is directly connected to the battery and only the motor signal wire (white) is connected to the ESCs.
Does that limit possible calibration options? I have BigQuad deck available if that can help with the ESC calibration.
Thanks in advance!
Thanks in advance!
