[SOLVED] re-enable propeller test in bolt - for safety!
Posted: Thu Aug 13, 2020 6:28 am
by wydmynd
We are having an intermittent issue with our bolt <--> ESC interface, that sometimes the ESC does not initialize correctly.
I decided the best way to avoid problems is to use the proptest in stabilizer.c , which is disabled for Bolt. This will be a test in much less than max thrust, and is much safer than having the drone fly uncontrollably upon takeoff.
Tried looking into re-enabling it, seems that something is blocking the function MotorsSetRatio from running, but I can't see what.
Would appreciate any help!
Re: re-enable propeller test in bolt - for safety!
Posted: Thu Aug 13, 2020 9:11 am
by tobias
I tested this today (only on an oscilloscope) and apparently the prop test is not disabled for the brushless motor driver... :oops:
So you probably just have to tune the max power and duration in the test and I think it should work. The current 50ms is probably to short for the ESC to react and start up the motor.
Posted: Sun Aug 16, 2020 7:59 am
by wydmynd
thanks for the check!
it was disabled in a way... ;) I am using small motors , used 450ms pulse with a power level of 20000, works great
