Problem compiling the firmware on Windows
Posted: Mon Nov 04, 2019 4:48 pm
Hi everyone,
I'm trying to build the Crazyflie firmware on Windows 10. I followed the instruction for Windows found here, but for some reason I'm getting the following error when trying to compile the firmware:
I did not make any modifications to any files in the crazyflie-firmware folder. I also made sure that the file arm_iir_lattice_init_q31.c does indeed exist at the specified location.
Any ideas what I can do so that the build succeeds?
Thank you.
CC ootx_decoder.o
CC lighthouse_calibration.o
make -C .//tools/make/cmsis_dsp/ CRAZYFLIE_BASE=/home/Florian/crazyflie-firmware PROJ_ROOT=/home/Florian/crazyflie-firmware V=
CC arm_iir_lattice_init_q31.o
arm-none-eabi-gcc.exe: error: /home/Florian/crazyflie-firmware/vendor/CMSIS/CMSIS/DSP_Lib/Source/FilteringFunctions/arm_iir_lattice_init_q31.c: No such file or directory
arm-none-eabi-gcc.exe: fatal error: no input files
compilation terminated.
make[2]: *** [../targets.mk:27: arm_iir_lattice_init_q31.o] Error 1
make[1]: *** [Makefile:365: libarm_math.a] Error 2
rm version.c
make: *** [Makefile:350: build] Error 2
Thank you.
