Currently, i'm working in order to improve crazyflie's EKF, because it is not accurate in my tests
Yaw behavior: https://ibb.co/QM50zW7
P.S: I'm using LPS.
I'm using CF 2.0 and these measurement was taked while flying. However, I did some tests while CF was not flying (docked in a base) and results are different than expected.arnaud wrote: ↑Tue Aug 20, 2019 7:45 am Hi,
What Crazyflie are you using (2.0 or 2.1) and are these measurement taken while flying or not?
The MEMS gyro of the Crazyflie will drift over time. The drift you observe is bigger than what I would have expected though (the gyro used in 2.1 is specified for a couple of degree drift per minute max).
When flying though, the LPS and the kalman filter should take care of the yaw and correct it using the flight dynamic.
