Adding motor drive to generate downward thrust
Posted: Sun Nov 11, 2018 8:07 pm
by zhanghaijason
I am wondering if downward thrust can be generated if I add motor drives to control the four motors. Thanks
Re: Adding motor drive to generate downward thrust
Posted: Mon Nov 12, 2018 12:32 pm
by tobias
It depends on what you mean. There are two possible solutions.
1. Reverse the direction of drive of the propeller. This requires a H-bridge driver which the Crazyflie does not have. Would be possible to build on a expansion deck though.
2. Using variable pitch propellers (as on helicopters). I have not seen any design that is small enough for the Crazyflie. It would also require new drive since both the propeller speed and pitch needs to be controlled.
Posted: Mon Nov 12, 2018 8:47 pm
by zhanghaijason
tobias wrote: ↑Mon Nov 12, 2018 12:32 pm
I guess H-bridge would be the solution since most of the time, upward thrust is used for normal flight and downward thrust is needed not very often.
Posted: Wed Apr 27, 2022 4:00 pm
by dastonge
Hello!
We also have a small research project going on for which we'll need to get bidirectionnal control of our Crazyflies motors. We managed to do it, for larger models, using the ESC+Bolt setup, but we now want to control the tiny Crazyflie motors with a dedicated custom deck. We plan to populate our deck with 4 H-bridges, such as
https://www.digikey.ca/en/products/deta ... R/15286883. We will hook them to the PWM signals (as it is done on the BigQuad deck
https://github.com/bitcraze/hardware/bl ... rev-c1.pdf), and several digital pins (ideally 2 are required for each H-bridge to get sleep and brake features). Do you have any other recommendation on the H-bridge chip or does anyone have tried this before?
Our current options for the digital inputs are:
- get 4 available digital outputs from the CF expansion pinout to control the Hbridge direction (forward and reverse have opposite signal - we lose the brake and sleep features);
- add an I2C chip to manage all of the H-bridges inputs;
- use different PWM frequencies for forward and reverse and detect the frequency change on our deck to swap the H-bridge control inputs.
Note that we also plan on using the flow deck v2 with z-ranging and maybe the LPS deck too....
Thank you for your support,
David.
Posted: Fri Apr 29, 2022 7:19 am
by kimberly
Could you please start a new forum thread for your question?
Posted: Tue May 03, 2022 2:21 am
by dastonge
Posted: Tue May 03, 2022 7:46 am
by kristoffer
Thanks!
