BigQuad ESC Beeping
Posted: Sat Apr 28, 2018 12:05 am
Hi, I built a bigger drone with BigQuad deck, however, one of the ESC is beeping.
Here is the log -
SYS: Build 34:71ebff013648 (2018.01.1-34) CLEAN
SYS: I am 0x333636353235510D002C0022 and I have 1024KB of flash!
CFGBLK: v1, verification [OK]
DECK_DRIVERS: Found 13 drivers
DECK_DRIVERS: VID:PID BC:05 (bcBigQuad)
DECK_DRIVERS: VID:PID 00:00 (bcRZR)
DECK_DRIVERS: VID:PID BC:01 (bcLedRing)
DECK_DRIVERS: VID:PID BC:04 (bcBuzzer)
DECK_DRIVERS: VID:PID BC:07 (bcGTGPS)
DECK_DRIVERS: VID:PID 00:00 (bcCPPM)
DECK_DRIVERS: VID:PID BC:08 (bcUSD)
DECK_DRIVERS: VID:PID BC:09 (bcZRanger)
DECK_DRIVERS: VID:PID BC:06 (bcDWM1000)
DECK_DRIVERS: VID:PID BC:0A (bcFlow)
DECK_DRIVERS: VID:PID BC:0B (bcOA)
DECK_DRIVERS: VID:PID BC:0C (bcMultiranger)
DECK_DRIVERS: VID:PID BC:FF (bcExpTest)
DECK_INFO: Found 2 deck memories.
DECK_INFO: Enumerating deck 0
DECK_INFO: Deck BC:05 bcBigQuad (Rev. C)
DECK_INFO: Used pin: 10011001
DECK_INFO: Driver implements: [ init test ]
DECK_INFO: Enumerating deck 1
DECK_INFO: Deck BC:0A bcFlow (Rev. E)
DECK_INFO: Used pin: 0000000C
DECK_CORE: 2 deck enumerated
DECK_CORE: Calling INIT from driver bcBigQuad for deck 0
BIGQUAD: Switching to brushless.
DECK_CORE: Calling INIT from driver bcFlow for deck 1
Motion chip is: 0x
si pihc noitoM: 0xFF
MPU9250 I2C connection [O<F>
This happens on the M2 side of the BigQuad. I have tested the motors and the escs separately using another FC.
Any ideas?
Here is the log -
Motion chip is: 0x
Any ideas?
