Failed to read data from EEPROM!
Posted: Fri Sep 01, 2017 1:53 am
According to the loco_node_revd.pdf. I finished my pcb and test . But find some problem . Failed to read data from EEPROM! Can tell me how to solve it?
Terminal ready
SYSTEM : CPU-ID: 390038000651485536343720
TEST : Initializing pressure sensor ... [OK]
TEST : Pressure sensor self-test ... [OK]
TEST : EEPROM self-test ... [FAIL]
CONFIG : Failed to read data from EEPROM!
CONFIG : Could not read data from EEPROM
TEST : Initialize UWB ... [OK]
TEST : One or more self-tests failed, blocking startup!
Help
0-9 - set address
a - anchor mode
t - tag mode
s - sniffer mode
m - List and change mode
d - reset configuration
h - This help
---- For machine only
b - Switch to binary mode (sniffer only)
Terminal ready
Help
0-9 - set address
a - anchor mode
t - tag mode
s - sniffer mode
h - This help
