I' making my first step in the "world of Bitcraze" and i need your help. I have a crazyflie 2.0, the crazyradio pa and the loco system position. I would like to use "crazyflie-lib-python" to fly crazyflie. Now i can execute some examples that i found in "crazyflie-lib-python" like basiclog, rump, ect.. but i can't use "autonomousSequence.py" in particolar i recive a error in the log config Kalman variance, the script can't found a variable toc Kalman. The code is exactly the same of "crazyflie-lib-python". I am using a linux system, and i don't know if the crazyflie it's new or an other student change the firmware. there is a method to reinitialize? thank you
the code the i would execute in python is:
import time
import cflib.crtp
# URI to the Crazyflie to connect to
uri = 'radio://0/80/2M' #i change it, i utilize the uri of my Cf
# Change the sequence according to your setup
# x y z YAW
sequence = [
(2.5, 2.5, 1.2, 0),
(2.5, 2.5, 1.2, 0),
(2.5, 2.5, 1.2, 0),
(2.5, 2.5, 1.2, 0),
(2.5, 2.5, 1.2, 0),
(2.5, 2.5, 1.2, 0),
(2.5, 2.5, 1.2, 0),
log_config = LogConfig(name='Kalman Variance', period_in_ms=500)
log_config.add_variable('kalman.varPX', 'float')
log_config.add_variable('kalman.varPY', 'float')
log_config.add_variable('kalman.varPZ', 'float')
var_y_history = [1000] * 10
var_x_history = [1000] * 10
var_z_history = [1000] * 10
threshold = 0.001
for log_entry in logger:
data = log_entry[1]
var_x_history.pop(0)
var_y_history.pop(0)
var_z_history.pop(0)
min_x = min(var_x_history)
max_x = max(var_x_history)
min_y = min(var_y_history)
max_y = max(var_y_history)
min_z = min(var_z_history)
max_z = max(var_z_history)
# print("{} {} {}".
# format(max_x - min_x, max_y - min_y, max_z - min_z))
max_z - min_z) < threshold:
break
def reset_estimator(scf):
cf = scf.cf
time.sleep(0.1)
wait_for_position_estimator(cf)
def position_callback(timestamp, data, logconf):
x = data['kalman.stateX']
y = data['kalman.stateY']
z = data['kalman.stateZ']
print('pos: ({}, {}, {})'.format(x, y, z))
def start_position_printing(scf):
log_conf = LogConfig(name='Position', period_in_ms=500)
log_conf.add_variable('kalman.stateX', 'float')
log_conf.add_variable('kalman.stateY', 'float')
log_conf.add_variable('kalman.stateZ', 'float')
scf.cf.log.add_config(log_conf)
log_conf.data_received_cb.add_callback(position_callback)
log_conf.start()
cf = scf.cf
cf.param.set_value('flightmode.posSet', '1')
for position in sequence:
print('Setting position {}'.format(position))
for i in range(50):
cf.commander.send_setpoint(position[1], position[0],
position[3],
int(position[2] * 1000))
time.sleep(0.1)
cf.commander.send_setpoint(0, 0, 0, 0)
time.sleep(0.1)
if __name__ == '__main__':
with SyncCrazyflie(uri) as scf:
# start_position_printing(scf)
