Strange LPS issue with ROS
Posted: Sun Mar 26, 2017 9:50 pm
Hello Bitcraze,
My team and I have been flying up to 3 drones for a month now and have been testing this system to try to work out as many bugs as possible. However, there has been one issue we have been seeing that we cannot understand what is causing it. It has to do with the terminal when you launch ROS. You can see the issue in the picture below. It shows in the terminal that anchors 6 and 7 parameters are not found, although it still shows all 8 anchors in RVIZ. Do you know what may be causing this?
We also tried launching 4 drones today, and had huge issues getting them to hover correctly. They took a very long time to calibrate their actual initial position, and then when we launched, they flew very erratically all around the room. We are suspecting that it may be because of the issue above that because there are less anchors in the system than there actually is, the drones position is being diluted without the last two anchors.
