Problem when opening VirtualMachine of Crazyflie on VirtualBox
Posted: Fri Mar 24, 2017 6:57 pm
by thanhvu94
I installed the VirtualBox version 5.1 (newest version) and BitcrazeVM_2017.03 as on the website. Then I import the Bitcraze into the VirtualBox and click the green arrow START. However, there is an error like this:
I have deleted the VirtualBox and reinstalled but the problem still persists. If anyone has solution to this problem, please tell me!!
Thank you.
Re: Problem when opening VirtualMachine of Crazyflie on VirtualBox
Posted: Mon Mar 27, 2017 12:32 pm
by arnaud
This looks like a conflict problem between virtual machine supervisor. It can be caused by having an other virtual machine software installed and/or running (like vmware or virtual PC).
Posted: Mon Mar 27, 2017 2:56 pm
by thanhvu94
arnaud wrote:Hi,
I have never used any Virtual Machine Software before, and I didn't find any software like you mentioned in my computer. I attached my Log file below, can you have a look to see what is the problem?
Thank you so much.
Posted: Tue Mar 28, 2017 9:40 am
by arnaud
Searching quickly on Google shows that this problem happens on windows, there seems to be a couple of procedure to fix it.
Anyway I tested the Bitcraze VM 2017.03 in Windows 10 running Virtualbox 5.1.18 and everything works fine for me, so it does not seems to be a problem related to the VM but more to windows or other software affecting Virtualbox.
