[SOLVED] Simple Hover Program
mrmks
Post by mrmks »
I am trying to run the simple hover program from another thread, but the parameter 'flightmode.althold' is not being set.
From 'basicparam.py', I can see the 'flightmode' parameter with althold as the first option. How can I make the hover program work?
Here is the hover program output:
hold
sending initial thrust of 0
putting in althold
Unable to find variable [flightmode.althold]
Cannot set value for [flightmode.althold], it's not in the TOC!
  File "/usr/lib/python3.5/runpy.py", line 184, in _run_module_as_main
    "__main__", mod_spec)
  File "/usr/lib/python3.5/runpy.py", line 85, in _run_code
    exec(code, run_globals)
  File "/home/miles/projects/crazyflie-lib-python/examples/alt_hold.py", line 13, in <module>
    cf.param.set_value("flightmode.althold","True")
  File "/home/miles/projects/crazyflie-lib-python/cflib/crazyflie/param.py", line 265, in set_value
    raise KeyError('{} not in param TOC'.format(complete_name))
KeyError: 'flightmode.althold not in param TOC'
and here is the code for the hover program:
import time
cf = Crazyflie()
print("sending initial thrust of 0")
cf.commander.send_setpoint(0,0,0,0);
time.sleep(0.5);
print("putting in althold")
print("Stay in althold for 7s")
it=0
while it<700:
    cf.commander.send_setpoint(0,0,0,32767)
    time.sleep(0.01)
    it+=1
print("Close connection")
cf.close_link()
Re: Simple Hover Program
You are not connected to a crazyflie, this is why you are getting this error. You should connect first before being able to send setpoint and set parameters. You can look at the ramp.py example to see how to connect and send commands to the Crazyflie: https://github.com/bitcraze/crazyflie-l ... es/ramp.py
mrmks
[SOLVED] Re: Simple Hover Program
Post by mrmks »
Thanks! Altitude hold is beautiful now, takes off from a bench and stays about 15 cm above.
Here's the code I used:
import logging
import time
from threading import Thread
import cflib
class AltHoldExample:
    def __init__(self, link_uri):
        """ Initialize and run the example with the specified link_uri """
        self._cf = Crazyflie()
        self._cf.connected.add_callback(self._connected)
        self._cf.disconnected.add_callback(self._disconnected)
        self._cf.connection_failed.add_callback(self._connection_failed)
        self._cf.connection_lost.add_callback(self._connection_lost)
        self._cf.open_link(link_uri)
        self.is_connected = True
        # Variable used to keep main loop occupied until disconnect
        print('Connecting to %s' % link_uri)
        """ This callback is called form the Crazyflie API when a Crazyflie
        has been connected and the TOCs have been downloaded."""
        print('Connected to %s' % link_uri)
        # Start a separate thread to do the motor test.
        # Do not hijack the calling thread!
        Thread(target=self._hover_test).start()
    def _connection_failed(self, link_uri, msg):
        """Callback when connection initial connection fails (i.e no Crazyflie
        at the specified address)"""
        print('Connection to %s failed: %s' % (link_uri, msg))
    def _connection_lost(self, link_uri, msg):
        """Callback when disconnected after a connection has been made (i.e
        Crazyflie moves out of range)"""
        print('Connection to %s lost: %s' % (link_uri, msg))
    def _disconnected(self, link_uri):
        """Callback when the Crazyflie is disconnected (called in all cases)"""
        print('Disconnected from %s' % link_uri)
        self.is_connected = False
    def _hover_test(self):
        self._cf.commander.send_setpoint(0,0,0,0);
        time.sleep(0.5);
        self._cf.param.set_value("flightmode.althold","True")
        it=0
        while it<700:
            self._cf.commander.send_setpoint(0,0,0,32767)
            time.sleep(0.01)
            it+=1
        self._cf.close_link()
if __name__ == '__main__':
    # Scan for Crazyflies and use the first one found
    print('Scanning interfaces for Crazyflies...')
    print('Crazyflies found:')
    for i in available:
        print(i[0])
    if len(available) > 0:
        le = AltHoldExample(available[0][0])
    else:
        print('No Crazyflies found, cannot run example')
Re: [SOLVED] Simple Hover Program
Great that it worked and thanks for sharing your code!
/Arnaud
weiyuh3
Post by weiyuh3 »
I tried the codes attached, my my crazyflie keeps shifting during flying. How did you solve it? Thanks for answering.
