[SOLVED] ar-detector : the program crash when it detects the marker
Posted: Thu Aug 18, 2016 12:31 pm
I everybody !
I'm using xubuntu 16.04 (no vm).
I'm trying to make the crazyflie-ar-detector works (github : https://github.com/bitcraze/crazyflie-ar-detector) . I was able to calibrate my camera with the program "calibrate_camera_charuco" from opencv_contrib.
Moreover, the program "detect_markers" from opencv_contrib is perfectly working.
The program made by bitcraze is based on the program "detect_markers" form opencv_contrib :
opencv_contrib program https://github.com/opencv/opencv_contri ... arkers.cpp
bitcraze program https://github.com/bitcraze/crazyflie-a ... arkers.cpp
I've compiled the program "detect_markers" made by bitcraze, and it works if it doesn't detect any marker. But when it detects a marker (e.g. when I place the marker in front of the camera), the program stop working.
I get this error :
In the while loop, the vectors rvecs and tvecs are not the same type.
bitcraze version (line 284) :
opencv_contrib version (line 177) :
I think that the method used here (line 289) :
has been changed since the release of the code by bitcraze.
With the original code form bitcraze I can compile and the program works until the method estimatePoseSingleMarkers(...) is called.
But if I changed the type of vector, I can't compile the program because of these lines (line 346) :
If tvecs is a vector<Vec3d>, the method .at can't be used.
To be sure of that, I've commented these lines and I was able to compile. Moreover the program detected the marker but with a position equal to (0,0,0) of course, because pos_x, pos_y and pos_z weren't changed.
A solution to this problem would be to install an older version of openCV3.
But it would be better to correct this problem !
Do you have any clue about this problem?
If you think that my problem is badly expressed, just ask me to rephrase or to add information.
Thanks,
Pierre
I get this error :
I searched a lot, and by comparing the code from the bitcraze program and the code from opencv_contrib, I noticed a change :OpenCV Error: Assertion failed (0 <= i && i < (int)v.size()) in getMat_, file /home/pierre/projects/opencv/modules/core/src/matrix.cpp, line 1201
terminate called after throwing an instance of 'cv::Exception'
what(): /home/pierre/projects/opencv/modules/core/src/matrix.cpp:1201: error: (-215) 0 <= i && i < (int)v.size() in function getMat_
Abandon (core dumped)
vector< Mat > rvecs, tvecs;Code: Select all
vector< Vec3d > rvecs, tvecs;Code: Select all
aruco::estimatePoseSingleMarkers(corners, markerLength, camMatrix, distCoeffs, rvecs,
tvecs);With the original code form bitcraze I can compile and the program works until the method estimatePoseSingleMarkers(...) is called.
pos_x = tvecs[0].at<double>(0);
pos_y = tvecs[0].at<double>(1);
pos_z = tvecs[0].at<double>(2);
Thanks,
Pierre
