Page 1 of 2
[SOLVED]cfheadless
Posted: Thu Feb 25, 2016 5:11 pm
by Mitteau
Hy
I tested cfheadless
Xubuntu 15.10. Xbox360 with ad'hoc json file. Last Python client.2019.09
The commands for the LED ring are OK with cfclient but do not function with cfheadless.
Thank you.
Regards
Jean-Claude
Re: cfheadless-Trim
Posted: Tue Mar 01, 2016 10:50 am
by Mitteau
Hello !
Trim command also looks inactive with cfheadless ?
Regards
Jean-Claude
Re: cfheadless
Posted: Sun Mar 13, 2016 5:50 pm
by Mitteau
If I understand correctly Python+Qt4, cfheadless does know alt1 neither alternative function nor trim adjust by input device.
Thank you for confirmation.
Regards
Jean-Claude
Re: cfheadless
Posted: Wed Mar 16, 2016 10:34 am
by marcus
The trimming for roll/pitch should work in cfheadless (otherwise it's a bug, see code
here) but the alt1/2 callbacks aren't added. You could add callbacks pretty easy,
using similar code as the client.
But since there's no way to configure the controller in the headless client you will have to already have set up the buttons for trimming/alt in the client and make sure to use the correct configuration.
Re: cfheadless
Posted: Wed Mar 16, 2016 3:30 pm
by Mitteau
Thanks Marcus
No problem with the controller for I make my own .json file which works correctly with cfclient.
I look at the software and send a comment.
Regards
Jean-Claude
Re: cfheadless
Posted: Wed Mar 16, 2016 4:16 pm
by Mitteau
Hello Marcus
These are the differences between my file and the one you indicate me:
1/ my file contains an "import sys" wich disapperars
2/ I have not "import cfclient"
Remaining code looks the same.
I download "crazyflie-clients-python-2015.09" from Github.
Regards
Jean-Claude
Re: cfheadless
Posted: Thu Mar 17, 2016 5:09 pm
by Mitteau
Hi
In Python3 interpreter, situated in .../cfclient/utils/input, import cfclient in __init__.py seems not necessary.
True ?
Jean-Claude
Re: cfheadless
Posted: Wed Mar 23, 2016 10:26 am
by marcus
I'm note sure about the __init__ in Python 3. But it's best to start from the latest revision on the develop branch in the repository. The version 2015.09 is a bit old and lots of things have changed.
Re: cfheadless
Posted: Wed Mar 23, 2016 10:49 am
by Mitteau
Hin thanks, I will test it when my copter will be back.
Regards
Jean-Claude
Re: cfheadless
Posted: Wed Mar 23, 2016 3:25 pm
by Mitteau
Hi
How can I know the version of the python client and the cf-firmware ?
Sincerely
Jean-Claude
