Gasia PS3 controller doesn't work?
Posted: Sun Dec 13, 2015 5:38 pm
I bought a PS3 controller cheaply off Ebay, but it turns out to be a clone - it identifies as 'Gasia' when I plug it via USB to my Linux laptop.
The Cfclient program sees the controller,
However, I can't get the program to detect any input from the controller. In the Flight Control tab, it has Thrust at 79% while no buttons are pressed. Attempting to configure device mapping doesn't seem to do anything either - I assume that it should register button presses, but nothing happens.
What am I doing wrong, please?
Many thanks
Phil
Dec 13 17:32:16 ThinkPad kernel: [ 815.460423] usb 2-1.2: New USB device found, idVendor=054c, idProduct=0268
Dec 13 17:32:16 ThinkPad kernel: [ 815.460433] usb 2-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Dec 13 17:32:16 ThinkPad kernel: [ 815.460438] usb 2-1.2: Product: PS(R) Gamepad
Dec 13 17:32:16 ThinkPad kernel: [ 815.460442] usb 2-1.2: Manufacturer: Gasia Co.,Ltd
Dec 13 17:32:16 ThinkPad kernel: [ 815.463934] input: Gasia Co.,Ltd PS(R) Gamepad as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2/2-1.2:1.0/0003:054C:0268.0003/input/input16
Dec 13 17:32:16 ThinkPad kernel: [ 815.517997] sony 0003:054C:0268.0003: input,hiddev0,hidraw0: USB HID v1.11 Joystick [Gasia Co.,Ltd PS(R) Gamepad] on usb-0000:00:1d.0-1.2/input0
Dec 13 17:32:16 ThinkPad mtp-probe: checking bus 2, device 6: "/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2"
Dec 13 17:32:16 ThinkPad mtp-probe: bus: 2, device: 6 was not an MTP device
Dec 13 17:32:16 ThinkPad upowerd[1062]: (upowerd:1062): UPower-Linux-WARNING **: no valid voltage value found for device /sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2/2-1.2:1.0/0003:054C:0268.0003/power_supply/sony_controller_battery_00:26:5c:3e:02:00, assuming 10VCode: Select all
INFO:cfclient.ui.main:Role of Gasia Co.,Ltd PS(R) Gamepad is Device
INFO:cfclient.utils.input.mux:Adding device Gasia Co.,Ltd PS(R) Gamepad to MUX NormalWhat am I doing wrong, please?
Many thanks
Phil
