Process PWM-Signal
Posted: Mon Dec 07, 2015 3:37 pm
by Che.
Hi everyone,
does anybody have an approach to process a PWM-Signal from a sensor?
Mine looks like this at the moment:
Create 2 Tasks:
First one to poll the GPIO-Port which is connected to the PWM signal in 10ยต-Second steps until end-condition is received, then suspend the task
Second one to wake first task in desired period time
I think getting an interrupt from the GPIO would be much more favorable.
Greets
Re: Process PWM-Signal
Posted: Tue Dec 08, 2015 9:20 am
by tobias
Maybe the
CPPM driver could give some ideas. It is using an input timer to take time stamps of GPIO transitions and then feeding that to a queue.
Posted: Mon Dec 14, 2015 1:06 pm
by Che.
Thanks for your reply.
Could you explain to me, how the input timer works?
I've managed to catch an interrupt with the transition on my GPIO-Pin (IO_3 on board), but the system stops working at the moment the IRQ appears.
I think i am lacking of saving the context of FreeRTOS.
Unfortunately I did not completely understand your CPPM-Driver, but it seems, as you are skipping the part i tried to program.
How is it possible, to catch the Flanks directly and start the timers? I also think the timers are depending on which GPIO-Port one is using.
I couldnt figure out, with which timer i need to replace TIM14 in the code when using PB5 as input. Or should i just switch to PA7 (which i assume you use)?
Thanks in advance.
edit: Where can I find the define for NVIC_CPPM_PRI?
edit2: The code works. But i want to count from a falling edge to a rising edge. There are three modes, rising, falling and both. Is it possible in one interrupt to only count the low time of the pwm signal? or do i need two interrupts, one for starting the counter at falling edge and one stopping the counter at rising edge?
and the second problem is, that i get big noise problems. I attached a screenshot. before this measurement i selected falling edge mode.
edit3: selecting both edges on the interrupt capture did the trick. now i get proper distance reading from my sensor. but the peaks are still there. anyone has a clue?
