PC client does not respond.
Posted: Wed Jun 17, 2015 12:19 am
We have a crazyflie 2.0 and we develop it with VM.
When we connect the drone with our PC client using crazyradio PA, the flight data does not always update. It sometimes works fine but it freezes for most of time. We already updated the firmware of Crazyfile, Crazyradio and have the latest version of PC client. We use a mac pro with USB 3.0 port.
Here are the logs from terminal and I attach a screen shot of the client to this thread
INFO:cfclient.ui.tabs.FlightTab:Changed flightmode to Advanced
INFO:cflib.crazyflie:Callback->Connection initialized[radio://0/80/250K]
INFO:cflib.crazyflie:We are connected[radio://0/80/250K], request connection setup
INFO:cflib.crazyflie:Callback->Connected to [radio://0/80/250K]
WARNING:cflib.crazyflie.log:Error no LogEntry to handle id=3
WARNING:cflib.crazyflie.log:Error no LogEntry to handle id=4
WARNING:cflib.crazyflie.log:Error no LogEntry to handle id=5
WARNING:cflib.crazyflie.log:Error no LogEntry to handle id=6
WARNING:cflib.crazyflie.log:Error no LogEntry to handle id=1
INFO:cflib.crazyflie.mem:Requesting number of memories
INFO:cflib.crazyflie.mem:1 memories found
INFO:cflib.crazyflie.mem:Requesting first id
INFO:cflib.crazyflie.mem:Memory: id=0, type=I2C, size=8191
INFO:cflib.crazyflie.mem:Done getting all the memories, start reading the OWs
INFO:cflib.crazyflie:Memories finished updating
INFO:cflib.crazyflie:Callback->Connection setup finished [radio://0/80/250K]
INFO:cfclient.utils.logconfigreader:Parsing [stabilizer.json]
INFO:cflib.crazyflie.mem:Updating content of memory 0
INFO:cflib.crazyflie.mem:Requesting new chunk of 16bytes at 0x0
INFO:cflib.crazyflie.mem:READ: Mem=0, addr=0x0, status=0x0, data=(48, 120, 66, 67, 1, 80, 0, 0, 0, 0, 0, 0, 0, 0, 0, 231)
INFO:cflib.crazyflie.mem:READING: We are still interested in request for mem 0
INFO:cflib.crazyflie.mem:Got new data: 0xBCP
INFO:cflib.crazyflie.mem:{'radio_channel': 80, 'roll_trim': 0.0, 'pitch_trim': 0.0, 'radio_speed': 0}
INFO:cflib.crazyflie.log:Have successfully started logging for id=1
INFO:cflib.crazyflie.log:Have successfully started logging for id=3
INFO:cflib.crazyflie.log:Have successfully started logging for id=4
INFO:cfclient.ui.tabs.FlightTab:[imu_sensors.HMC5883L]: 1
INFO:cfclient.ui.tabs.FlightTab:[imu_sensors.MS5611]: 0
INFO:cflib.crazyflie.log:Have successfully started logging for id=5
INFO:cflib.crazyflie.log:Have successfully started logging for id=6
