So... it happens that I still have a DSM2 transmitter lying around from an old try at RC helicopters which appears to talk a different language (so to speak) than the ESKY transmitter that already has some support built-in into the firmware. More precisely it's an Eflite LP5DSM:
I opened it up and the transceiver chipset is this one:
WirelessUSB™ LP 2.4 GHz Radio SoC
Features
2.4 GHz Direct Sequence Spread Spectrum (DSSS) radio transceiver
Operates in the unlicensed worldwide Industrial, Scientific, and Medical (ISM) band (2.400 GHz to 2.483 GHz)
21 mA operating current (Transmit at –5 dBm)
Transmit power up to 4 dBm
Receive sensitivity up to –97 dBm
Sleep Current less than 1 μA
DSSS data rates up to 250 kbps, GFSK data rate of 1 Mbps
Low external component count
Auto Transaction Sequencer (ATS) - no MCU intervention
Framing, Length, CRC16, and Auto ACK
Power Management Unit (PMU) for MCU/Sensor
Fast Startup and Fast Channel Changes
Separate 16-byte Transmit and Receive FIFOs
AutoRate™ - dynamic data rate reception
Receive Signal Strength Indication (RSSI)
Serial Peripheral Interface (SPI) control while in sleep mode
4 MHz SPI microcontroller interface
Battery Voltage Monitoring Circuitry
Supports coin-cell operated applications
Operating voltage from 1.8V to 3.6V
Operating temperature from 0 to 70°C
Space saving 40-pin QFN 6x6 mm package
If it does, I'd be interested into making this work with the Crazyflie (although my guess already is that I got so used to my XBOX controller for flying it now that I wouldn't want to switch). However I would probably not be able to do so alone (while I'm a software engineer, my field of expertise lies more within front- and backend development, not in embedded programming -- yet), which is why I created this thread
I'm also aware of the possibility to talk PPM from the TX to the Crazyradio, and if anyone could provide me with some schematics here I'd also be eager to try that out. Still... using the TX directly is somehow very interesting
Cheers,
Gina
PS: I'm also very tempted now to get myself an ESKY TX on ebay... Damn you Bitcraze!
