Altitude hold in Python API
moejoe
Post by moejoe »
Hi all,
thanks for building all this amazing stuff.
My question: With my crazyflie 2.0 - is there a way to invoke altitude hold mode through the Python API?
moejoe
Re: Altitude hold in Python API
Post by moejoe »
Okay, I got an idea now. It seems to be
crazyflie.param.set_value('flightmode.althold', true);
Going to try that now.
Yes this is how you enable altitude hold, once enabled the thrust sent to the copter is interpreted as vertical rate where 32767 is 0. See https://github.com/bitcraze/crazyflie-c ... ut.py#L275 for scaling implementation in the joystick driver.
