[Not Solveable][Hardware Issue][CF-1] M4 spins when off
Posted: Thu Feb 05, 2015 4:13 am
				I recieved a crazyflie nano as a christmas gift, and just took the time to solder it up today. It was flying perfectly fine for roughly two hours until the M4 motor started to spin even while the board was powered off.  The motor does not spin when connected to USB without the battery, but will spin continuously when both are connected, even after the battery is removed. If thrust is given after disconnecting the battery, but leaving USB connected, the motor stops.
I did a search, and the consensus seems to be that the mosfet went bad. I'd been charging and discharging pretty much since I put it together. I checked my solder job, and it doesn't seem that the pad shorted to the nearby ground pad either. I contacted Seeed and am waiting for a reply, but I'm wondering if there could be any other issue. I had to contact Seeed through customer support because I didn't have an order number, not sure if that affects anything.
If I'm stuck fixing it, can I have some suggestions for alternative MOSFETs? NXP has put the EoL out for the current one. It looks like mouser has these available, but they're out of stock on digi-key, so we'll probably need an easy to source alternative for the community anyways.
The person who gave it to me explicitly said "Try not to break it the first day." Irony at its finest.
