CF2.0 Debug Adapter How to question.
Posted: Sat Jan 10, 2015 9:59 pm
Hi
I would like to set my self up to be able to debug the firmware. I've done a bit of research, but I don't have clear picture on how it all fits together and what i can actually do with it in addition to being an easy way to perform a low level flash.
To set myself up, would I be correct in assuming I need to buy a Debug Adapter and possibly something like the Bus Blaster v3/4. Use a Jtag cable to connect the DebugAdptr and Bus Blaster together and then I could run OpenOCD / urJtag or similar to debug the firmware.
Another thing which is not clear to me, will I be able to perform some form of 'Source Level' debugging with this setup. ie compile with debugging on, set break points and have code stop at specific lines, or will I only be able to see processor registers.
Many thanks in advance.
